#26 |
Timing & Scoring Chief If the event results arent posted feel free to PM me about it.
He runs them with carbs, so I'm guessing he likely uses the stock line. I need more flow for E85 and a LOT more pressure for EFI.
I think I've got a good idea now though. The fuel cell will be in the stock tank area. Planning to relocate the battery up front too to simplify wiring and move the weight balance a little. Pump will be under the hood and I'll route lines in the lower channels under the pan. I might have to use both sides ... one for send and the other for return. Not sure yet. Those lines are pretty rigid, so I'm not sure I can fit both in one channel with some of the bends required.
__________________
Matt W. 18 SM - Lancer Evolution MR 15 MR - Volkswagen Beetle Sponsors: Satellite Racing - Defined Performance |
#27 |
2010 Rallycross Chair
Matt..If its strictly for Rallycross, run braided outside the cabin. Heck it doesn't matter what fuel you use. Its flammable! You don't want that in the cabin with you if shit happens. Maybe even if your wearing a flame suit. In rallycross, its very unlikely....Don't over think!
It will be a royal PITA to run them through the channels. All that trouble for no gain. Keep it simple & neat.
__________________
ALSCCA Rally Chair 2009 Eastern States Rallycross Champion(PR) 2010 Rallycross National Champion(PR) 2011 Rallycross National 10th Placer(M2) 2012 Rallycross National 4th Placer (PA) |
#28 |
Going back to this topic, I think I have my routing figured out. I'm going to run the lines in the channel where the body bolts to the pans.
BUT, I'll need to shape the line a little. I've read where people boil the nylon lines to fit them over barbs and such. Anyone see issue with using a heat gun or similar to warm them and shape them in angles less than 90º? I just need a couple of bends to make them conform to the chassis and not hang down.
__________________
#29 | |
I voted for Bush twice!!!
Quote:
__________________
M. Cholewa Because they heard I liked my name, so they put my name as my name so I could have my name in my name... all the time. |
#30 |
Driver
We put the nylon into form fixtures and then inject steam inside the nylon at a specified temp and pressure for a certain amount of time. The parameters we use all depend on the nylon, PB562, PB443, PB444? After that we cool them by pushing water through and then compressed air, the times for each depends on the set we need for the form and nylon used.
As for inserting the quick connectors or inserting a steel tube into the nylon we just flare the ends of the nylon and then force in the connectors using automated insertion machines. The connectors are dipped in a lubricant before the process. Of course that's just how we mass produce nylon fuel and vapor lines for an OEM. That might be a bit more than you need to do for your one off application ![]() Edit: To add something that might be helpful the heat guns work great for getting the quick connects back out of the nylon. They tend to overheat and melt the nylon and would be difficult to use for forming purposes. Again depending on the nylon used heating inside out or outside in can make a big difference.
__________________
- Jerry Ledford 99 M3 STU / TBSP 24 |
#31 |
That is good info. Thanks!
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Brand new Garmin Nuvi 855 top of line GPS | claym | For Sale | 0 | 10-11-2010 09:41 AM |
| starting line video? | kilgojr | Photography & Video Share | 1 | 07-28-2010 11:53 AM |
| For Sale Evo Carbon fiber fuel door cover | lancer2quick | For Sale | 2 | 05-30-2010 10:17 PM |
