#1 |
Racer
![]() We've added a TrackCross to our Fall Event at Talladega Gran Prix Raceway!
Register Here: http://msreg.com/2018falltgpr TrackCross- Essentially it's an Autocross on a race track but instead of tons of cones, the course is run between two points on the track. A few cones may be used on the course but if you drop a wheel off the track your run will be DNFed. Participants WILL NOT be required to work the course. **The TrackCross portion of the event will be run on Sunday from 12-5 and will cost $50 with an entry cap of 50 participants.** Volunteer for a worker position for the rest of the track weekend and receive a FREE ENTRY for the TrackCross (limit 10)! Convertibles will need factory roll-over protection or a roll bar. Here's an example of a TrackCross run at Memphis Raceway: https://youtu.be/zNEn2ecg7fQ
__________________
Delanie Calhoun '90 Spec Miata '13 Ford Focus ST |
#2 |
Driver
![]() Just registered for Track Time and Track Cross! Good thing Hankooks wear like iron, right...?
__________________
2001 Green Miata 1991 White Miata 2007 Black Miata 29 CSP I part out Miatas @ theMiataFix.com |
#3 |
Racer
![]() I neglected to mention the track is supposed to be doing patch work in turn four (the "skid pad") before the event which should improve grip and tire wear!
__________________
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Fall TGPR Event **Plus TrackCross** | DelanieC | Time Trials | 15 | 09-27-2018 06:21 PM |
