Alabama Region Sports Car Club of America
Go Back   Alabama Region Sports Car Club of America > Resources > Technical
Notices
Reply
Thread Tools Display Modes
Old 02-19-2013, 11:04 PM   #1
jledford
Gets messy with Nessy
jledford's Avatar
Default 245 or 255 tire on a 9" wide wheel?
I'm debating on what size tire to put under the M3 for the season. I have a set of 17x9" wheels coming in soon and it's about time to order tires. I plan on sticking with Hankook RS3s for the first part of the season with a possible switch to the Rivals once those are released. The RS3's are literally $8 more for the set of 255/40s versus 245/40s. That's $8 total, not per tire. I want to stick with the RS3s over the ZII right now for money savings and track day use.
I've talked with the wheel supplier and I should be able to fit 255 tires with my current modifications. This will be a square setup on the car, no stagger. However I've read some articles where certain cars were faster with a 245 on a 9" wheel versus a 255 on the same wheel. Then on the other hand the guy that won STU at Nationals last year was running 255s on an M3. Perhaps the taller 255 tire helps with the gearing some as well.
So what sayeth the ALSCCA crew, 245/40s or 255/40s on a 17x9" wheel?
__________________
'07 350Z - being built for STU
jledford is offline   Reply With Quote
Old 02-19-2013, 11:55 PM   #2
kilgojr
ex Solo Chair for Life and no longer with RE goodness
kilgojr's Avatar
Location: the rattle can aisle, checking out the ricer colors
Default
going by Tire Rack, a 245 on a 8.5 gets you 1/2 inch more tread then a 235 on a 8. They don't show Tread Width of a 255, but the 255 on a 9 gets you 1/2 inch more Section Width then the 245....this is inline with the 245 from the 235. In Autocross, the more rubber you can get under the car, the better the results (in my experience, even at the cost of more weight on each corner). I know Sean has been running 255's on his M3, ofcourse he has double the horsepower you do, but the car is very well balanced. I think he wants more tire underneath his car, which would be good when you have 400hp.
So for my 2 cents, I'd order the 255's.
__________________
kilgojr is offline   Reply With Quote
Old 02-20-2013, 12:20 AM   #3
nickvagner
Holla holla fo' dollas
nickvagner's Avatar
Default
Bigger is better. Plus, when you get those halfway used up and are tired of them, that's the size I like to run on my 240
__________________
Nick V.
That white car with too much differential.
nickvagner is offline   Reply With Quote
Old 02-20-2013, 01:04 AM   #4
Cholewa
R.I.P.
Default
I ran 245's on a 7'' wheel and it was meh.
A tiny pinch of stretch is better than a swath of tread you can't even use. You can always change the sidewall size to enhance (or suckify) gearing.
This goes great with my thread asking where the benefit of tire size drops off. It's too bad we never got a solid answer.
Get out a calculator and figure out your contact patch for each, the overall diameter (to determine any gearing change) and weight differences. That data should help you determine which one is best for you.
__________________
Cholewa is offline   Reply With Quote
Old 02-20-2013, 07:26 AM   #5
rodhx
Rodinator
rodhx's Avatar
Default
In this case you likely want the 255s if they fit in the wheel wells. Then we need to find a day for me to come to Auburn and test fit your wheels/tires on my car
On the other hand, regarding the RS3s it has been shown that the 225/45-15s are at their best when slightly stretched on 9" wheels versus 8" wheels. I wonder if that means for that particular tire you would be better off with 245s???
I will be staying on 245s for a while. That's what is on my car and I had no fitment issues during sunday's test-n-tune.
__________________
2015 Ecostang
rodhx is offline   Reply With Quote
Old 02-20-2013, 09:30 AM   #6
bimmertech
How do I F Mod?
bimmertech's Avatar
Default
What Rod said. I was just too lazy to type it all out.
__________________
Casey Stallings
caseystallings@live.com
It's all fun and games until someone loses an everything.
bimmertech is offline   Reply With Quote
Old 02-20-2013, 11:11 AM   #7
e30Racer
Solo Chair for Life / Time Trial Chair / Member of the Green Party
e30Racer's Avatar
Default
Go with the 255's. Here's what's likely to happen if you go with the 245s....
You like the 245s in the RS3 and they handle well. Then the Rivals come out and you're thinking about getting them. Then you're back to the question of...245s or 255s? The RS3 245s are nice, but you could use a little more grip. So you say you'll go with the 255s in the Rivals, but then Rivals are too expensive and then you say well I'll stick with the RS3s, but I am going to try to the 255s next time.
The moral of the story is that in the end, you're probably going to end up getting 255's in either RS3s or Rivals down the road, so why not just go ahead and get the RS3s in 255s now.
Another way to look at it, similar to what Rod said, whatever your constant is (17x9 wheels in your case Jerry, 225 tires in Rods case) you want to fit it with the biggest variable you can. If you have 9in wide rims, fit it with the bigger set of tires (255s). If you have a 225 tire, fit it with the bigger rim, the 9in rim.
If nothing else always remember....Bigger is Better (in moderation)
__________________
Mark K
1989 BMW 325i
1990 BMW 325i
2013 BMW 135i
e30Racer is offline   Reply With Quote
Old 02-20-2013, 07:02 PM   #8
HPEVOX
No shirt, no problem
HPEVOX's Avatar
Default
255 RS3 should be square on a 9" wheel. My 265s are square on 9.5" wheel as you saw Saturday. And remember Jerry
Mine = 1" bigger diameter... and .5" wider
__________________
Heath Patterson
Tech Chief
ES 25 NB Miata
HPEVOX is offline   Reply With Quote
Old 02-20-2013, 07:31 PM   #9
e30Racer
e30Racer's Avatar
Default
What exactly do you mean by "square"?
__________________
Mark K
1989 BMW 325i
1990 BMW 325i
2013 BMW 135i
Old 02-20-2013, 07:47 PM   #10
HPEVOX
HPEVOX's Avatar
Default
Quote:
The sidewall is near perfect perpendicular to the ground when 265 is on 9.5" wheel. this >> Square = l__l .. not this herrafrush = \__/ nor this /__\ racecar
__________________
Heath Patterson
Tech Chief
ES 25 NB Miata
Old 02-20-2013, 08:26 PM   #11
e30Racer
e30Racer's Avatar
Default
do you think that square sidewalls are best?
__________________
Mark K
1989 BMW 325i
1990 BMW 325i
2013 BMW 135i
Old 02-20-2013, 08:37 PM   #12
HPEVOX
HPEVOX's Avatar
Default
I know his main concern was with fender clearance the other day. Just saying how it would fit on the wheel and how it would/wouldn't tuck under the fender. I'm sure he prefers 255s (guessing), but seemed like it was more concern with tucking in or not.
I have no insight on BMW gearing
__________________
Heath Patterson
Tech Chief
ES 25 NB Miata
Old 02-21-2013, 12:46 PM   #13
Cholewa
R.I.P.
Default
A pinch of stretch is best, the more sidewall the more squirm and the less crisp of turn in.
__________________
Old 02-21-2013, 03:22 PM   #14
JohnW8
I like yellow.
JohnW8's Avatar
Default
In my "testing" I've found that a stretched tire requires more air pressure to maintain a good contact patch, whereas a "square" sidewall allows for more adjustability of pressures without caving in the center of the contact patch. With a pinched sidewall you need higher pressures to get rid of the wallowing on the sidewall.
__________________
JohnW8 is offline   Reply With Quote
Old 02-21-2013, 03:56 PM   #15
nickvagner
nickvagner's Avatar
Default
It depends on the kind of tire being used. The cheaper and less "sporty" the tire, the more benefit you MAY see from some stretching on the wheel. If the sidewalls are inherently soft and squishy, running a slight amount a stretch (along with the added air required) you can get rid of a little sidewall flex. But as you get more into tires designed to have a less comfy sidewall that is designed not to flex, but rather withstand greater lateral loads, you will see less and less of any previous advantage, and will only see benefit from simply fitting more rubber underneath the car.
Basically, stretch the all-seasons to make them less crap (still crap), and pinch the r-comps/slicks all you want, because those sidewalls aren't giving regardless of air pressure.
There will always be a point of diminishing return where going bigger will either no longer achieve greater results or may start being slower (usually not the case with tires). Finding that balance really just takes either experience, testing, or some combination of both. For that kind of tire, I really see no reason not to go wider unless either the rules do not allow, or if you're going to have fitment issues that are not allowed to be addressed within the rules (i.e. fender rolling/pulling isn't allowed in that class). I think more often than not, the more rubber you can get under the car (again to the point of diminishing return) the better it will be.
Also, a 245 vs. 255 "stretch-wise" on a 9" is almost not noticeable at all. On a wheel that size you'll need to drop down to at LEAST a 235 before you'll be able to tell there's any stretch whatsoever. I ran a 225 on mine for a while, and it was just slightly stretched.
Go bigger!
__________________
Nick V.
Old 02-21-2013, 05:22 PM   #16
Cholewa
R.I.P.
Default
At a certain point cost should be the decider, if it's only 8 bucks more for a full 10mm added tread, you might as well. If it was 80 more, it might not be that big of a benefit.
__________________
Old 02-21-2013, 05:44 PM   #17
nickvagner
nickvagner's Avatar
Default
Quote:
Well yeah I guess cost is another factor, but I had ignored that one for the slight difference that he had already mentioned.
__________________
Nick V.
Old 02-21-2013, 10:45 PM   #18
jledford
jledford's Avatar
Default
I appreciate all of the input. I do believe I'll be ordering the 255's and doing what is necessary to make them fit on the car. I shouldn't have to do anything that isn't ST legal. I wanted to get 17x9.5's and try to squeeze 265's on it but from everything I researched I couldn't do that without pulling the fenders which isn't ST legal.
__________________
Old 02-22-2013, 07:13 AM   #19
rodhx
Rodinator
rodhx's Avatar
Default
Quote:
Originally Posted by jledford View Post
I won't tell you if I have to do anything that isn't ST legal.
FTFY
__________________
2015 Ecostang
Old 02-22-2013, 04:25 PM   #20
nickvagner
nickvagner's Avatar
Default
^ truth!
__________________
Nick V.
Old 02-27-2013, 05:27 PM   #21
jledford
jledford's Avatar
Default
The BFG Rivals are now showing estimated arrival of 3/29 and estimated delivery for my zip code of 4/4 on Tire Rack. It'd be one more event without good tires but I could go straight to the Rivals. It also looks like they went up in price from the previous estimate on tire rack, they're now the most expensive option in the 255/40R17 size of the three ST tires. So now I'm thinking I'll wait for the Rivals and just buy one set of tires this year since they're over $200 more per set than the RS3s.
Edit: I think it's because I'm looking at 255's now instead of 245's on the Rivals. The 245's still aren't available until middle of May and they're almost $150 cheaper per set than the 255's... decisions, decisions.
__________________
Old 02-27-2013, 07:30 PM   #22
nickvagner
nickvagner's Avatar
Default
Save the money and go RS3
__________________
Nick V.
Old 02-27-2013, 09:37 PM   #23
HPEVOX
HPEVOX's Avatar
Default
Depends on how competitive you want to be if there is someone close in your class and how much money you want to spend in the end. It's not like we're winning anything big by being .1 seconds faster. I have to remind myself of that sometimes when I want to spend moneys on it.... I rarely listen though as you have noticed lolz
__________________
Heath Patterson
Tech Chief
ES 25 NB Miata
Old 02-28-2013, 03:12 PM   #24
jledford
jledford's Avatar
Default
As of now there is no one in my class. I was just thinking the RS3s might not last the entire season with the auto-x and track days I want to do. Therefore I might have to buy two sets.
The Rivals are suppose to wear better from all the preliminary reports so I might be able to get my entire season on one set of tires. Plus I thought I might switch to the Rival if I bought the RS3 first. So I have some decisions to make.
__________________
Old 02-28-2013, 05:08 PM   #25
nickvagner
nickvagner's Avatar
Default
No tire will last a whole season of autox AND track days without being heat cycled beyond their max levels of adhesion. However, the RS-3's I got from C have had basically two autox seasons on them (with C and Sara co-driving) and a couple track days on that tire-eating monster of an Evo, and there's still a fair chunk of tread left. Granted, they don't grip like they should as they've been heat cycled thoroughly, but there is still "meat" on the tire.
I think you'll find it difficult to find a tire that wears much better than the RS-3 within the category of tires we all consider useful. If you're already considering buying two sets, and you aren't even worried about competition, that's all the more reason I'd go with the cheaper of the two!
__________________
Nick V.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How wide is too wide SamC Technical 8 01-25-2013 04:58 PM
Wheel/tire opinions - 5x112 issues TouringBubble Solo 15 02-10-2011 06:12 PM
Lets Talk " wheel spacers" c-evoVIII Solo 5 09-30-2010 08:43 AM
Want to by 15" Miata wheel rodhx Want to Buy 0 10-19-2009 10:09 PM
Want to by Miata wheel center caps 15" engled Want to Buy 8 09-29-2009 01:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright 2018 ALSCCA (Alabama Region Sports Car Club of America)
